or quilter block if you don't mind a bit of solid state
but after years of denial even I've gone frfr
Peavey, Laney, Carlsbro, HH, Yamaha etc all make various models that will fit the bill, or if you're feeling like spending all of that money instead of only about the first hundred quid, Roland.
For 50-100 quid, it's worth a go I reckon.
I do exactly this with my preamp-based pedalboard, and it sounds immense. What I've also noticed is that while the presence control is absolutely horrible when you use the JCA22H's preamp, it suddenly becomes awesomely useful when you're just using the amp's power section.
The solid state solution seems worth a go for pin money
Trace Elliott tramp /supertrampSS ?
I did forget to mention solid-state Fenders too, which aren't bad.
