Line 6 m5 plus an ex 1. You could pick up both relatively cheap used.
Or a Gloknob. Not sure you can buy them in the UK, but if you can just stick it on your favourite pedal.
I wish they'd reissue it.
Dr. Scientist The Elements has a mix knob, and a jack that lets you connect an expression pedal to, to control the mix
The volume into fuzz would work but takes 2 pedals! That's twice the cost!
A nice axis fuzz (my home built is shite wiring...) and a volume pedal would probably do though.
