Hi all,
I recently bought a Victory V30 from a very nice gentlemen. I have a couple of questions as I do not have any prior experience with Victory amps. Any help would be greatly appreciated.
1) When I plug an effects pedal into the effects loop, there is a "thud" every time I click the pedal on and off. May I know why this is happening?
2) There is a slight hum/buzz/hiss when the amp is on. Is this normal for all Victory amps?
Just to clarify, the hum is from the head itself and not the speaker. You have to be really close to hear it.
Thank you very much in advance for the help.
Cheers,
Keith
https://www.facebook.com/groups/508554529270876/
Hi Photek,
Thanks for the reply. No the pedal is powered by a 9V battery. I have tried the TC HOF and the TC Flashback. Both have the same issue. Changed cables too. I tried the pedals with my HT-5 and it does not pop.
I do not want to post there first as the seller is in the group. Might not seem very nice. He is a great person, so I am looking for an easy fix to put this episode to rest.
As to the mechanical 'hum' - transformers can exhibit this. I have a rack reverb unit that hums slightly which is emphasised when it's rested onto a hard tabletop (I have it sat on a piece of acoustic foam). I would check all the casing screws on the Victory are tight - if slightly loose, the casing may be accentuating the vibration noise.
Thank you for the reply. I would try that soon. I have no idea if it has a valve-driven fx loop. I am probably less technologically inclined. The amp is however less than a year old, seems strange to have to change the tubes.
Valve amps aren't as fragile as they are sometimes made out to be. But, at the same time, valves are replaceable parts that do wear (particularly power valves). Welcome to the wonderful world of 50s technology.
First, you need to know if there is anything inherently wrong with the amp or whether it's a minor problem.
I'll put up the bat signal for @ICBM (hopefully he won't mind) who will be able to give you some technologically sound advice on how to go about working out what is happening.
Popping when turning mechanically-switched pedals on and off is usually caused by a DC leak, yes - if the Blackstar amp doesn't do it it sounds like the problem is the Victory, rather than the pedals. If the FX loop is valve-driven (or returned), try changing those valves. Or alternatively, set the pedals to buffered bypass if that's an option - it's better anyway. If not, you could use a buffered loop pedal like the Boss LS-2 to put the affected pedals in.
Some slight physical noise from transformers is normal and not usually a sign of problems - some do it, some don't. It can sometimes be fixed by loosening the mounting bolts and retightening them (allowing the transformer to flex a bit), but if not and the problem is coming from inside the transformer there's usually nothing you can do about it other than replace the transformer.
Thanks for the quick reply. When you mention changing the valves, do you mean I should buy a new set of valves? I will try the buffered option later and report back.
Cheers,
Keith
