If you're open to other options I'd take the Atomic Amplifire.
@Fiftyshadesofjay
Thanks for the recommendation, may I ask why you'd go with the Atomic Amplifire over the Axe FX standard?
Cheers all!
And you need a foot controller.
For that - I'd go with the Helix LT instead.
thanks for the recommendation, would you say the Helix tops the Axe FX standard?
Cheers
IMHO (others will disagree) I think the Helix tops the Axe FX 2. When you see Helix -v- Fractal -v- Kemper arguments, they are all talking about the lastest tech versions. All are several generations beyond the Axe FX Standard.
It's got decent sounds and ongoing current support. It'll also be easier to use
You really should try one or all of the above, the punters might not care but as a guitarist a 'decent tone' won't put a smile on my face
I'll take a look at the helix, thanks guys.
Yeah I've been looking around and everyone seems to be comparing kempers and pods to the axe fx II mostly.
The majority seems to think Axe FX II is better than the POD HD PRO X, but my curiosity is about the Axe Fx standard.
@guitarfishbay
What are your thoughts on the Axe FX standard?
With the Atomic you get a fully supported modern generation modeller built into a decent footswitch, especially if you go for the Amplifire 12.
I do do agree that the Helix Lt look like it'll be a good shout as well.
