Gents,
I have a 5E3 which is power scaled and running a 5V4 rectifier
I have been reading that it might be an idea to go to a higher cathode bias resistor with the rectifier to cool the bias - current value is 270R and the suggestion is to go as high as 390R
With the power scaling engaged, I only get 7.5v pin 8 to ground and a voltage Pin 3-8 of 127v - That gives me a heady 2W dissipation and a plate current of 13mA
If the PS out of the circuit, I get 24v pin 8 to ground and a plate voltage of 356v - 15W and 42mA, which looks a touch high
Now, if I go off the amp at full whack, a 390R cathode bias resistor brings that down to 10W and 29mA
330R would give 12W 35mA
300R would give 14W and 38mA
However, with the scaling is (and how I'm, playing it) that would drop the plate current to 9mA with 390R and 11mA with 330R
So - what to do?
Forget any other measurements as they're not relevant.
