Charlie Chandler at CCGX may be able to help
I was just about to suggest PedalMods but it seems they only repair those on their mod list but it might be worth a sneaky try if all else fails- http://www.pedalmods.com/
Good luck
http://tagboardeffects.blogspot.co.uk/2012/02/fulltone-ocd-all-versions.html
If not that, the output jack - which is the only thing following the switch inside the pedal - may have got turned round so it's touching something it shouldn't, or (rare but possible) have failed so it's partly shorted itself.
@ICBM. Think it must be the output jack. I took it off my board and tried it with various cables.
If you suspect it's the jack it would be well worth opening the pedal to check if there's anything obviously wrong. If it is just shorting on something it would be much easier for you to move it than to send it all the way to juansolo for him to do that.
If it isn't that, then stick to plan A.
