That assumes it's got external mounting flanges of course - if the holes are inside the chassis you'll need to work it out entirely by measurement. Masking tape is useful for making reference markers.
Make the holes about 1-2mm oversize so there's some room for movement.
I would get some stout white card and cut it to fit the inside of the box. Then centre the chassis on it and mark it as a template for drilling. Drill 3mm or so holes to start with and get someone to 'eyeball' you to keep vertical (a drill press is vastly better) It is surprising how much 'wander' you can get in just an 18 mm thickness!
Because I am an anal old sod about such things, I would then insert pins in the holes and test the pins slide thru the chassis mounts. If all is ok, open out with the clearance ICBM suggests.
See, if you FU with the ~3mm holes you can plug with dowels and wood glue then flush them off and have another go the morrow!
Dave.
Tape the template to the top and drill through it.
I'll be doing the same sometime to save weight on my 95lb Bad Cat combo, so I'm glad you asked the question
