I'll stick with my Fuzz Factory and Fuzz Face.
I cannot find out where in the signal path the transformer is used? I would have thought on the output as here it could be driven hard and from a low source Z . It would also give the additional advantage of earth isolation. However, the claim of 'true bypass' makes that a bit pointless as looping out all the electronics removes all ground loop isolation!
If fitted at the very front, i.e. driven by guitar it would have to be of special winding specc' to give a high enough impedance and the result would, IMHO be VERY guitar and control setting sensitive. The pedal would also be very susceptible to hum pickup (the picture show NO shielding!)
All a bit of a money grabbing gimmick I reckon. Why go for a Big Name quality traff when you want to DISTORT the fekker?!!
Anyone interested in transformers can get one that is easily good enough for 'guitar' and neg ten operation from OEP electronics . A '600 Ohm' type 1200 should serve. On the OUTPUT! (around a fiver!)
Dave.
