CLOSED FS -Hardware/parts for Fender style guitars inc. Callaham/ Wudtone
Having taken an objective view of the projects that i have underway, I've decided to sell a few parts which aren't going to get used (no trades thanks).
All prices include postage to your home address, and assume payment by PPG. If you want to collect and pay cash then that's fine, and in that event I'll happily knock off the postage cost. I'm located near Bury, just north of Manchester.
Only the gold Mighty Mite two point trem system is still for sale - all other items are now SOLD.CALLAHAM/WUDTONE TREM NOW SOLD!Callaham/ Wudtone trem system (no saddles) - £65A Wudtone 'Holy Grail' bridge plate with shim and mounting screws (56.3mm mounting holes/ 52.5mm string spacing) mated with a Callaham 52.5mm string spacing enhanced steel block, with virtual pop-in '64 length arm (black tip), springs, claw and claw screws. You will need to provide your own 10.5mm wide saddles.
FENDER TELE BRIDGE NOW SOLD!Fender vintage Tele 6 saddle bridge - £25New and unused in original packaging, this made in USA bridge is a replacement for vintage style bridges (4 screw mount), but has six adjustable saddles (as fitted to many 1970's Tele's). Chrome finish.
FENDER WHITE HSS STRAT PICKGUARD NOW SOLD!Fender HSS Strat pickguard, white - £10New and unused (packaging opened), this is white-black-white (not parchment, mint or whatever) and fits Mexican and US guitars. 11 mounting holes.
BOTH FENDER NECK PLATES NOW SOLD!Fender big 'F' neck plates, two available- £8 eachFender big 'F' / CBS style neck plates in chrome with screws. One new and unused in original packaging, the other used only briefly and in as new condition. £8 each - first to buy will get the new/ unused item.
Mighty Mite two point trem system, gold - £15
A complete two point trem system, including springs, claw and pivot posts. This has never been installed, but it has picked up a little wear in the 20 years that it's been in my parts box! There are a couple of tiny marks to the plating and some wear to the plating on the arm where it appears to have rubbed against something (just about visible in the 3rd picture). The mounting centres for the posts are (very) approximately 69mm. String spacing is 54mm. I have no idea what this will retrofit, so please check the measurements/ask questions before purchasing.
http://i.imgur.com/Eol9Rlf.jpghttp://i.imgur.com/1ofol1t.jpghttp://i.imgur.com/ru33sE7.jpghttp://i.imgur.com/0G4Hxkr.jpgCheers, CasperCaster.
Fender neck plates and Fender Tele bridge are now SOLD.
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
