Hi, I am thinking of forgetting a low wattage tube amp and getting a Jet City JCA2212c and then making an L-Pad to go with it, I'll probably make it Switchable and between 10 and 20 dB.
I'm just about to come up with a circuit diagram, but just wanted to make sure my calculations are correct for the 16 ohm speaker in the combo.
For 10db of attenuation, I would get roughly 2 watts of output with a 11 ohm 15 watt series resistor and a 7.5 ohm 5 watt Parrallel one.
For 20db of attenuation, I would get 0.2 watts of output and would need a 14.5 ohm 18 watt resistor and a 2 ohm 2 watt resistor.
Of course my numbers have been rounded off to the nearest 0.5 as I don't think they make fractional resistors, also I may increase the power ratings to support larger amps which I might use in the future.
Can someone please verify these calculations.
https://www.circuitlab.com/circuit/55ms7stk3kg4/switchable-l-pad/
http://cpc.farnell.com/monacor/at-62h/high-power-l-pad-mono/dp/LS00547
https://willys-hifi.com/collections/l-pad-attenuators/products/l-pad-attenuator-100w-8-ohm-wirewound-volume-control-1
EDIT: Something like this: https://www.circuitlab.com/circuit/7h4xx6qm8wmj/variable-l-pad-16ohm/
The resistances don't need to be at all accurate if you're building a separate-element one - bear in mind that the impedance of a speaker varies by a factor of at least 4 or 5 over the audio range anyway.
Thanks, do you recommend anything other than an L-Pad that would work better, I'm sure the master volume on the Jet City is pretty good, but not sure if it will be enough.
Also, I'm going to put this in a seperate box, what wire and jacks should I use?
Proper Switchcraft 1/4" open-frame jacks (not copies) or Cliff/Re-An plastic 'Marshall type' jacks (probably the best). Any fairly decent gauge cable is fine - ripped-down light gauge power cable is fine if you don't want to spend money.
