I'm a bit confuzed. I wanted a brighter, stratty tele neck pickup, and everyone more or less recommended the Twisted Tele. So far so good. After some more digging on the forums I came across a few articles on pickup output reading, high/low output, etc. But, a few of the pieces said that the Henries measurement was a much better reading to go by to determine how a pickup is voiced - brightness, mids or bass.
So I compare the Henries reading on the Twisted Tele with a CS Nocaster neck pu I already have - Twisted is 4.3 and the Nocaster is 2.3. If I'm not mistaken, the higher the henries reading indicate more lows, mids and bass. Based on these readings the Nocaster pu should have more chime and brightness??
Anyone shed some light on this?
Presumably the extra volume of wire on it adds a bit of inductance too, but then the addition is on the bottom of the pickup where there won't be a whole lot of output, so perhaps it's negligible.
The increased inductance seems a lot more than I'd put down to those two factors alone though, I'd imagine the wind is probably hotter too.
