Hey folks
I've juat started delving into the world of recording (currently using my thr10 amp as the interface between the guitar and GarageBand but plan on getting something like a focusrite Scarlett to use) and I want to add piano sounds into my recordings.
What do I need? I see all different types of keyboards from small things right up to full size electric pianos.
Looking for cheap and cheerful so will probably be buying used.
Ideally I'd like to be able to use it as a piano without NEEDING to plug into a computer or interface but that's a secondary thing. I really know nothing about any of this at this stage so all input much appreciated!
Thanks
https://www.amazon.co.uk/gp/aw/d/B01AT0IIBS#Ask
Am i on the right lines ?
If your going further into recording then you could use this as a master keyboard (I think) and play 3rd party software Piano sounds.
https://twitter.com/spark240
Reddit r/newmusicreview
So it's not the audio that's being recorded as such, the keystrokes on the keyboard/piano are mimicked by the virtual instrument, yes?
How authentic are the sounds? Obviously unless it's an actual piano then these 'virtual' sounds are in effect no different to what's coming out of the keyboard/piano in the first place?
Probably sounds like stupid questions but trying to get my head around the terminology!
I don't know whether I want something small that doesn't look/feel like a proper piano which is just a controller or something like what I linked which can be played as a standalone instrument with no computer connection.
Yes. Exactly that.
If piano sounds are your main focus then an 88-key weighted controller will be much better than a smaller keyboard, and I think it's worth getting something you can use standalone as well so you're not put off by having to start up the computer to play.
The other thing to look out for is the action of the keyboard, the most basic ones (synth action) don't really play like a real piano. If this is important to you, the best thing is to go to a shop and try a few to see what works for you.
