Any experts care to chip in with which speakers you would wire up together?
Spare speakers:
2 x hot100 8ohm,
2 x G12H100 4ohm,
1x vintage G12 8ohms (older version of a vintage30),
1xG12M70 4ohm
I have a spare 4x12 and an oversize 2x12.
I'm not particularly tied in to needing a certain overall impedance.
I was going to wire it up as option A until I spotted the other two speakers so I could go with option B
Option A cab1 hot100 + V30 (16ohm) cab2 G12H100 + G12H100 (8ohm)
Option B cab1 V30 + G12H100 + G12H100 (16ohm) cab2 hot100 + hot100 (16ohm)
Anyone spot another combination? Any preference which combination will work better?
Both cabs are closed.
If the G12H100s are anything like the 30s or 75s then I'd probably put those in the smaller 212 cab as the extended range (compared to a v30 type) would make it sound bigger.
