Dunno if I'm going mad, this has me a bit perplexed.
I have had at GT100 for around 6 months and have discovered the following to do with the System / Output Select.
As it is in the System menu, I have always assumed it is a global setting applying to all patches. Seems the right way to go I think.
When I do gigs with a house amp in place, I try a few outputs - sometimes JC-100 or Stack or into the power loops I use the Return versions.
My patches are all ready setup and this is just to tune to the house amp.
However, I have just found to my surprise that the output amp setting is saved with each patch. So I have ended up with different patches with different outputs selected. This makes for hassle when I turn up and then need to change the output for each patch and save it there and then.
Surely, this should be a global setting so that you set it once and it applies to all patches? In fact, I can't believe that I have only just noticed this and am sure something has changed.
Does everyone else's work like this?
Guitarist for... HEY PIXIES - The UK's most gigantic PIXIES tribute band
http://www.facebook.com/heypixies"We don't actually own any of this gear - we're just looking after it for the next Fretboarder."
After much angst for ages, of course I found the setting pretty soon after my posting.
There is a setting to make the output per patch or global.
It's in System / Preferences. Pretty obvious really.
I swear I never changed it!
