I keep thinking about giving a Red Special a try, the only thing which puts me off is that it's one of the few guitars in the world recognisable to significant numbers of non-guitarists and it might prove embarrassing that my band doesn't have a single Queen song in the set... :-)
In stock form, I actually found it difficult to access a wide range of tones without fiddling with the amp or jumping on pedals. With the new pickups, it's much easier, everything from icepick-to-the-eardrums treble to smooth cello sounds just through the controls.. It's a great gigging guitar with a ton of different sounds available; the only one I can't crack on it is modern metal.
Also, it's a great excuse to talk the band into doing a Queen cover
In fact quite a few of their alternative colour schemes look cool. http://shop.brianmayguitars.co.uk/brian-may-guitars.html
Part of the reason for the headstock size and shape was to create a straight string pull from the nut to the machine heads, as he and his dad realised that friction was the enemy of tuning stability, especially when using a tremolo.
So what the fuck are they doing splaying out the strings like that? Horrible!! I'm surprised at World Guitars for that.
Modern nut materials can eliminate friction at the nut, so it's a non-issue, provided the nut is cut properly. With bone or plastic it was more likely to happen, and so that was a wise precaution then.
http://tertl.blogspot.com - personal blog
Greatly reduce the effects of, maybe.
Even so, bearing in mind the design was 1) more elegant, 2) had greater functionality its a shame that they aren't "right".
