I have bitched and bitched about the POD HD 500. It's got rubbish footswitches. The effects loop is horrible noisy and they attenuated it and the return to hide that. It's underpowered (as is the 500x). The signal routing is absolutely insane and takes a lot of sussing out before you know how to use it right (I do now). The rubbish effects loop and terrible signal routing make trying to get the four cable method working a real pain. The headphone out sounds very poor - but run it into a mixer then headphones and it's okay.
But...
I've been getting fed up of fiddling around trying to get sounds that work for me. I'm bored of it. I spent 15 years when my ONLY guitar gear was an Epiphone superstrat, a Korg G3, a Crybaby Wah and a Marlin solid state amp - and I gigged that regularly. Hardly play live now and I have two valve amps, two modellers and a full pedalboard of effects. I'm constantly fiddling with sounds rather than just playing. I spent more time mucking around with technology when I pick up my guitar than playing anything. This is partly due to loving tinkering with technology to be honest, but also stupid tone chasing.
I'm fed up of GASing for new gear. A sport that seems more fueled by showing folks on forums what new gear I have than really enjoying what I have. Seems the most fun buying new gear is right up until one hits "confirm purchase" on a website. I bought a Zoom MS70-CDR a couple of weeks ago. It's great. But I'm not sure what I bought it for or how it fits into the fear I play with. £80 gone in a blink of an eye.
When I have used my POD HD 500 with a valve amp I've tweaked the tones to death, switched off cab sims, used the pre-amp models and tried to make the device act like a real pre-amp in front of the real amp's power stage. But given how low I'm playing at home (though thanks to living in a detached vicarage I often get to crank my gear at home - which is nice) really there's no reason not to let the POD simulate a power amp too - adding some warmth - as the power stage on the real hamp is hardly cooking.
So this week - brought on by my post on the Favourite Amps thread about my old Marlin 50C (expanded in
this blog post) and spending ages trying to rid my pedalboard from hum I plugged the POD HD into the power amp of my Ironheart. My only tinkering was to set the POD into Stack Power Amp mode. I selected an amp model - the Plexi at first I think - set the gain in the middle, added some reverb and delay and then played for an hour. It was fabulous.
Did the POD give me the best sound I've ever had? No. But it sounded like a real amp, a really good amp. There was no hiss, no annoying glitches or hums. It was a super simple signal chain. Guitar > POD > Amp Head. Simple. And I just played and played for the first time in absolutely ages. I didn't worry that "I've got this great amp head here, surely I should be using its preamp" or "you spent a fortune on flashboack and hall of fame, you should be using them" or "what would people think of the rig". I just played. And it was fun. Have done the same a few times since then. Sometimes trying a different amp model each session. The Vox AC30 is nice. No idea if it sounds like a real one. Don't care.
Ironically it's tempting me into another bit of GAS. I think I'm going to sell some pedals and pick up a Blackstar ID head. (despite my piss taking of their marketing in the past). Bored of fannying around with all manner of kit. Both for home noodling and the occasional gig. I want an amp that sounds good, doesn't need special care for its glass bottles and has some nice effects onboard. I think I've reached a point where I'm not that arsed about how amazing it may sound, given my gear history. Also like it because there's no effort to copy other amps, just offer some interesting tone options. I like effects, if I didn't then my Laney Cub12R would be the answer on its own, but I'm a geek, I like bloops and pleeps. So a modelling amp with effects might answer.
But right now I'm having lots of fun with the POD HD. You should try one, they are great.
I only tend to get the amp out at home when I've got a new pedal to play with and then I spend my time working out how to get the best sounds out of the pedal rather than learning stuff.
I can definately relate to this, I'm also a software developer and have a general dislike to multi fx as I get bored of going through menus tweaking. Much prefer just to plug something in that sounds right from the start.
I still think that bit is fun (and expensive!) but for now, I'm enjoying the playing, rather than the tweaking.
For now (I've recently acquired a HD500) I'll be going straight to the PA and use the effect return of my Mustang III for "stage" monitoring.
http://line6.ideascale.com/
That means I can't set the 1/4" to Combo amp (plugged into Mustang III return) and the XLR to Studio direct (straight to PA mixer).
How stupid is that???
Thanks for the link, Fretwired, I have now registered and ...
... voted for "Dual output modes".
I do not intend to spend hours tweaking sounds, I'll simply pick one or two amps I like as the basis of all my patches and add effects if and when needed.
