Gotohs are 6.35mm post diameter.
I don't think you can find a suitable bush unless AVRI tuners have that particular combination.
My suggestion for a non- destructive fix would be to use the SD91 bushes (8.8mm) and make a sleeve to get a tight fit.
http://axecaster.co.uk/blog/?p=832
I might pop these into the parts draw for another built (or post here for sale) and get the right spec Pings.
Do Axecaster have a direct fit for the lovely '60s Classic neck?
These come with around 9.1mm bushes. Only difference is they're not split post.
.1 of a mm is probably within the margin of error!
You can use a little bit of superglue in the hole too, if you're careful with it. But normally a few winds of PTFE will do the trick.
These are the right spec, I understand:
http://www.ebay.co.uk/itm/122482269664?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
