Hi,
I'm looking to swap out the original bridge pick up on my Aria Pro II XL for the TWB-20. However, the Tokai only has 3 wires, whereas the original (and every wiring diagram I can find) show 4 wires.
Also, I don't know whether the TWB-20 is intended for bridge or neck placement.
Question #1 - Can I determine which position the pick up is intended for?
Question #2 - Could anyone point me in the direction of a suitable/relevant wiring diagram?
I have searched for '3 wire Humbucker pick up wiring' and for the actual pick up model itself and not found anything 'useable'.
The 'XL' has a coil tap, off of the tone pot.
Any help or pointers would be greatly appreciated.
Thanks in advance.
Ash.
1 - I'd start with coil spacing - anything exceeding 50mm is likely bridge, failing that take a resistance, if it's over 8.5k is likely to be a bridge
2 - just use any wiring diagram for a two conductor (braided) wire and ignore the split wire (take resistance readings between the wires to work out which one is the split)
