So im about to pull the trigger on some new valves for my Grandmiester 36. Ive had it a long time now and Ive always been lucky thay tubes have never failed. However, i may be looking to try some different valves to change the sound a little.
Clean channel is fine
Crunch i never use as its not a crunch, more like flubby tone rather than a crunch
Lead is a little "metallic" sounding. Its not terrible but Id like to see if i could i get rid of it.
Ultra i never use.
So would a different el34 ina certain position change the flub on the crunch channel? Thoughts?
Changing the 12AX7s might make a difference, but it's still unlikely that you will be able to change the relative voicing of the channels much, if at all - this is a hybrid amp and all the tone control is done in the solid-state section.
Ok i may just got for a standard replacement set rather than the stock tubes and maybe fiddle later on.
If tonal change is what you seek, investigate replacement loudspeakers.
Jusafort but. 'Flubby' bass might JUST be knackered OP valves?
Dave.
Maybe, but if so I would expect it on all the channels rather than just one.
A similar problem with tweaking anything by changing the preamp valves is that all the valves operate on all the channels all the time, so if there are radical differences between the channels it's unlikely to be anything to do with the valves.
The glaringly obvious suggestion is to try the head "as is" through some other loudspeakers. Perhaps, you can find a more sympathetic match for the Meister?
EL84s are wonderful for some applications and not to my liking for others. If you are accustomed to small 6V6-powered Fender guitar amplifiers, the Blues Junior just does not sound or feel right. Same goes for some of the Bassbreaker series. Fine amps but not properly "Fender".
Ultimately, the amplifier is only one element in your signal chain. Its behaviour depends to some extent on your other gear and your personal playing dynamics.
