ISO Cabs
monquixotemonquixote Frets: 17598
in Amps tFB Trader
I'm looking for an ISO cab, but I want a full range speaker in it rather than a guitar one (It's for testing microphones rather than recording guitar)
Anyone know a maker that lets you pick the driver?
  • DodgeDodge Frets: 1435
    No, but is the Jet City one is cheap enough to buy and change the speaker?
  • photekphotek Frets: 1463
    Worth seeing if you can find the Jet City ISO 2 so you have 2 mic's at once. I quite fancy one for home recording to be honest.
  • KoaKoa Frets: 120
    Got all excited there thinking there was a new international standard for speaker cabs , possibly :) :) ISO4x12:100w......just me then...
    won't you need a tweeter for FR?
  • digitalscreamdigitalscream Frets: 26564
    edited May 2017
    This is the immediate problem. I don't know of any PA driver which will get close to where average human hearing tops out, much less the 20kHz upper limit of tweeters. Even if you decide to put a tweeter in there, you're going to have some serious problems with sound distribution between the main driver and the tweeter vs mic positioning.
    Perhaps a bit more info on what you mean by "testing mics" might be helpful...?
    <space for hire>
  • monquixotemonquixote Frets: 17598
    Ideally I wouldn't want a 12" speaker (which is all the more reason not to replace the driver in an existing ISO cab), but I could get something like a Celestion FTX1225 which goes up to 20k
    It's actually not that big a deal if I don't have up to 20k as there is not a huge amount of energy up there and it's not really important for what I'm doing.
    The application is "work stuff" so I can't go into too much detail, but essentially testing the performance of relatively low end consumer microphones at various sound pressure levels.
  • SickSquidSickSquid Frets: 152
    Demeter's ISO cab comes unloaded. I sold one on here a couple of years ago.
    If you could persuade Rivera to supply their Silent Sister unloaded it may be a great option.
    I say that as they need some way for the sound to be dispersed from inside such a small enclosure, which that one does. Either that, or make your own around a traditional cabinet using sound deadening materials. I ended up doing that and it sounds better than anything else I've used.
  • ToneControlToneControl Frets: 11889
    I have one for sale, it was custom made
    you can use a monitor cab inside it
    I'm pretty sure I bought that and have it in storage somewhere
    If you are interested PM me and I could look it out for much cheapness (It's probably costing me more to store than it is worth)
  • maltingsaudiomaltingsaudio Frets: 3126
    Something like the dual concentric in an AER would be best in my opinion for what your doing it's an 8" Beyma  and fairly linear in response. The carpentry is up to you
    www.maltingsaudio.co.uk
    If you're testing mics, you don't want to use an ISO cab. It will influence your results too much.
    Why do you say that?
    Iso cabs add their own sound
    You need to engineer it out when you use the tracks
    Small enclosed spaces will cause resonances and comb filtering that the microphone will pickup, meaning huge boosts in certain frequency areas and huge cuts in others. You wont get an accurate measurement of the microphone for this reason.
    Even if they're treated this is true, because the treatment used in those boxes is usually low density foam which doesn't work well for bass frequencies.
  • guitarfishbayguitarfishbay Frets: 7959
    Exactly this.
    Treating bass frequencies purely with absorption takes a lot of space, and isn't possible in a typical ISO box. Put simply they will sound boxy and not be representative of flat.
    A better solution (though I have no idea if financially viable in this scenario) may be to look for your closest academic facility with an anechoic chamber.
  • ThorpyFXThorpyFX Frets: 6127
    I have a JETCITY one for sale £150 Mint condition as new. It is being sold due to a lack of space. the gear room upstairs is turning into a nursery!
    Adrian Thorpe MBE | Owner of ThorpyFx Ltd | Email: thorpy@thorpyfx.com | Twitter: @ThorpyFx | Facebook: ThorpyFx Ltd | Website: www.thorpyfx.com
    That's no use then :(
    Exactly this.
    Using a studio room at the moment but it costs money and requires arranging.
    Exactly this.
    you could use an empty field - the ultimate anechoic chamber
    you can average out to cancel out any background noises
    Exactly this.
    It's quite a long test so it gets done overnight.
    I'm not sure my kit would still be there!
