I used to have a 62 reverberocket which someone had put a vintage 30 in. Swapped it out for the Jensen p12q which almost halved the weight and sounded much better too.
i'd go with the Alnico speaker!
hotrox have the p15n for £145 which seems quite good for an alnico 15". The WGS 15 is £250.
see if you can find some comparisons on YouTube between the 2 types and see which you prefer. It's all down to personal taste in the end.
