Hello, I've acquired a Tele in trade recently (78 I think). Now the pickups seem a little shot particularly the bridge. I have a set of Custom Shop nocaster pickups that I've never used.
So should I pay to get the guitar serviced and the pickups rewound or would the custom shop jobbies be a worth while step up from the stock. Obviously it would be easier if I could AB the pickups so I could decide but money is tight at the moment so would rather not pay for unnecessary work if it can be avoided. I no intention of selling the guitar so keeping it stock is not a priority just want a nice tele workhorse.
Words of wisdom most appreciated.
I binned the pickups from my 1972 as they were so abysmal. I'm told I should have kept them as it would make the guitar more vaulable. Oh dear, how sad, never mind.
Personally since you have to take the pickups out anyway even to wax pot them, and if you have a set of better pickups to hand, I would put the better pickups in and keep the originals (in original knackered condition) safe for any future collectors who may want them...
The bridge is microphonic & the neck all bit dissapears with the tone control so I guess I have the best of both worlds:)
I'll swap the pu out and keep the originals as suggested.
Thanks for settling my mind.
Potting pickups is a very quick and cheap process, if you were planning on reselling them I'd advise doing it as they don't appear to be vintage level valuable judging on the previous comments.
The tone control killing the pickup output is a classic sign that the coil is open-circuit at the ground end, because the remainder of the coil is still attached at the hot end and will still partially work by capacitive coupling, but sounds thin and weak. This is common on old Fender pickups because the coil bobbin is open to the air via the tooling holes, and if moisture gets in it tends to cause a little spot of corrosion between the magnet and the coil wire which eventually eats through the wire on the inside end of the coil, which is the ground end usually. You can't fix it without rewinding the pickup.
I disagree, all working 70s pickups have some vintage value, far better to do as ICBM suggests and put them away safely 'as is' in case a future owner wants totally unmolested units. All wax potting on vintage pickups carries a risk of disturbing something and sending a unit open circuit. If it ain't broke, fix it.
