All the tele pickups I make have Nickel covers ... plus (sorry for the plug) I sell them separately on my site. I got fed up with (Bugger)Allparts never having them in stock so I started importing them myself
They are a bit of a faff to fit ... as you need to bend the lugs very carefully to avoid breaking them (nickel is a tad less malleable than brass).
Remember to plan ahead when you do the job ... I like to pre bend the two tabs at the rear edge of the cover and then angle the tab at the front slightly forwards ... so that you can slide on the cover with the lugs clear of the windings ... then last of all bend the single front tab into place. I don't solder the earth 'tail' back to the single lug ... I attach a separate earth to one of the back legs and run that back to a pot ... that way if you ever want to do a 'phase switch' you already have a 'lifted' earth. If you have an issue I'll do a photo series on here first to let you see how I do it.
Single coil noise doesn't worry me much, but there are folks who get as anal as a sea cucumber about it
