All the best
You should see the power valves and the phase inverter still glowing, and the other preamp valves dead.
You can fix it permanently by fitting the heatsink that Marshall saved a few pence by not doing, and resoldering it.
It's also worth fitting a couple of rubber grommets around the upper rear chassis bolts to increase the cooling gap slightly.
