Tell me about Lava Tightrope patch cables
gibsongretschfangibsongretschfan Frets: 1050
Are they any good? How do they compare to the Evidence SIS ones?
and before anyone says "solder your own" I usually do but having space issues
  • GagarynGagaryn Frets: 1553
    edited May 2017
    Tightrope is Lava's budget cable. It has a solid core so it can be shaped but is more prone to break. Evidence is multicore - can't be shaped but is less likely to break. Lava do other kits too with multicore cable like ELC and also do other plugs that fix with a grub screw - called Piston and also do soldered plugs which are a similar size to the solderless ones.
  • xscaramangaxscaramanga Frets: 436
    Got a few Tightrope cables on my boards. Never had any issues with them. I'm not very good at practical stuff and I find making them pretty easy.
    My YouTube channel, Half Speed Solos: classic guitar solos demonstrated at half speed with scrolling tab and no waffle.
    Occasionally have to chop a cm or two and redo them but generally ok for pedalboard use
    I just bought the ELC kit - was £45 at Bax which seems reasonable. Normally make my own with pancake jacks but they don't play nice with Strymon pedals as the sockets are too close together.
  • lincolnbluelincolnblue Frets: 294
    My board is wired with them and I've never had any problems at all.
    This is my problem too. Would you recommend the Piston then? Or should I man up and go Evidence?
  • How does everyone feel about mixing and matching patch leads on a board? I'm not very OCD but the thought starts to make me shudder
    Depends what you want to spend. If you are going to do a lot of changing about on the Board I would go soldered. Solderless are all inherently weaker. My Board only has 5 pedals on it - they don't get changed about.
  • hotpickupshotpickups Frets: 1819
    edited May 2017
    Me too. I've been using Lava solderless for years and they've never failed on me. Mind you once my pedals are on the board they don't get moved around frequently so why wshould they fail. I use SIS jacks too and more than happy with them too. SIS feel a little better made personally though i.e. better machined . I don't hear anything sonically though and sound just the same to me
    All I'd say about the ELC jacks is they ripped my hands up when screwing them together
    Well, I made up the ELC cables last night. Have to say, it's a bit of a faff, certainly do not chose these thinking it is easier than soldering. That said it's not complicated, they all work and the plugs have a small enough diameter that they fit next to each other on Strymon pedals - unlike pancake jacks. They stick out about the same distance as pancake jacks though so don't think you will save any space that way.
    I wore a pair of marigold rubber gloves to help with the tightening. And because I like wearing marigold rubber gloves. These were black ,"Smell The Glove" limited edition marigolds. :-)
  • digitalscreamdigitalscream Frets: 26561
    They're fine, as long as you don't swap your pedals about much. If your board makeup is pretty stable, they're great.
    Still, I always carry a few regular patch cables around, just in case. Then again...I always have, whether I was using solderless or not.
    <space for hire>
