Following on from that interesting thread about peoples biases against SS -
I am really thinking about swapping my Tweed Blues Deluxe for a Roland JC 40. I know the clean sound is revered and used widely in reggae.
I play in a 9 piece Ska band - so there is competition with horns and keys in the EQ band.
I play clean most of the time. I love the sound of my Blues Deluxe when its warm, its pretty clean, warm and creamy.... I am nervous I'd loose this 'warmth' to a colder more digital sound with the JC 40.
I have a bad back so the weight would be a significant bonus.
My other issue is pedals - I'd use my EP booster as a clean volume boost and can't imagine this would behave too differently with a SS amp as opposed to the Blues Deluxe. However, I use a tube screamer for solos and I'd imagine this would behave quite differently with a SS amp?
I like a moderately increased level of crunch, volume and sustain for solos. Would I need a different pedal?
I am thinking I could probably ditch the BOSS CH1 off my board as the built in chorus on the JC 40 sounds pretty sweet.
What are people's thoughts?
I'd like to rent/borrow one to get a really good feel for it. Anybody fancy a swap?
As ever YMMV
Id suggest a Bandit.
The OD channel on the 40 is completely different than the (much disliked)one on the 120 so you might find you can use that in place of a pedal too.
The JCs were designed (this is a Dan from TPS story) basically as pedal platform amps years before that concept even existed for other people. Just bear in mind that they won't 'take' pedals in the same way that your Deluxe will - less interaction with the amp as it were.
Peavey also do (or did anyway)a Special Chorus which is basically a 2x12 Bandit with chorus ( the modern version, not to be confused with their 80s Stereo Chorus which is built like a brick shithouse) which ticks a lot of the boxes here and turns up cheap.
I have notion of pairing a JC40 with my Laney combo, switching amps for those clean twinkly moments and when no one is looking running both at once and pretending to be Billy Duffy.
I haven't played a JC40 yet but I'm very familiar with JC120s and the other older models. They are definitely cleaner and more hi-fi than the Blues Deluxe, but still a rich, warm sound which takes pedals well.
I would stick with the Fender amplifier and run an Equaliser pedal to fake the Roland JC sounds.
I recommend you try out a new Mustang GT. These amps do Fender cleans very, very well plus there are some very nice built in effects. If ever you wanted some crunch or gain, there are other amp models in there too (21) and some OD pedal effects built in (it has 47 effects). The reverbs and delays are very good too, esp the Fender amp based reverbs that are very authentic . Although a digital modelling amp, the tones are surprisingly warm & valve-like, and the amps are very light weight - the new GT is just unbelievably light - even the 2x12 GT200 is only 32lbs! Plus they are very competitively priced - even the top of the range 2x12 GT200 is only £440 and it comes with a 4-button footswitch for good live gigging control.
You can see the spec here - its state of the art, is wi-fi enabled, and even includes a looper:
https://www.andertons.co.uk/p/2310306000/combo-amps/fender-mustang-gt-200-200w-2x12-digital-combo-amplifier
The demo vids are very impressive:
https://www.andertons.co.uk/p/KTN100/combo-amps/boss-katana-ktn100-electric-guitar-amp-combo
Have a look for the Peavey special. It's a 2x12 bandit but with more watts and a nifty stereo chorus built in.
Or a boss katana maybe. But I've only heard that in person played crunchy...
Twice the power, half the price.
Alternatively look at getting a small folding sack barrow to move you present amp about, then your only problem is the lift in/out the car boot.
Not that being digital would make it bad—indeed, it might explain why the distortion is better than usual for a Jazz Chorus amp, since Boss/Roland has had some success with digital drives like the OD-1X in recent years.
Suspect the chorus and verb are digital which is a good thing imo. Drive I'd suspect was analogue.
I could go the 120 - but they are pretty heavy.
Think I'll stay put.
Thanks for the input people.
