Need advice on new pickup
StevepageStevepage Frets: 3044
I took my Jackson along to rehearsal tonight and was a little bit let down with the tone. Too much top end and just sounded a bit shrill compared to the Washburn with an EMG81 in the bridge.
It's a Bill Lawrence L500XL in the bridge of the Jackson, what pick up would you recommend that had high output but had a much fatter tone?
    I've heard good things about an Oil City Nightfighter Custom in a Jackson. My friend tends to like very Thick, Full tones as well.
    What kind of stuff are you playing? I think the best passive high output hum bucker i've ever used is the Dimarzio Crunch Lab, its very immediate in the attack but with some insane depth and clarity. If i was playing modern metal, it would be my first choice.
  • StevepageStevepage Frets: 3044
    Think of the band Epica but with a more aggressive tone. Big open chords and chunky/aggressive palm mutes.
  • MolochMoloch Frets: 693
    You can't really go wrong with a Duncan JB or Custom 5.
  • guitarfishbayguitarfishbay Frets: 7959
    Have you tried Duncan Blackouts? Like EMG 81 bridge but fatter and a bit more output.
    I have a set of the standard Blackouts I'd sell if anyone is interested.
  • professorbenprofessorben Frets: 5105
    Dimarzio ToneZone.
    Its made to put lowend into Floyd equipped Alder/Basswood guitars.
    I might be.
    How much?
    I might be.
    How much?
    @professorben ;
    £85 posted, pickups only.
    Been giving some serious thought into the Tone Zone. Looks like it may be exactly what I'm looking for.
    As for actives, I'd rather not go that route for this one. I have EMGs in two other guitars so I'd like a bit more variety #firstworldproblems
  • FunkfingersFunkfingers Frets: 14409
    Stevepage said:
    Jackson + Bill Lawrence L500XL compared to the Washburn with an EMG81 in the bridge.
    Were both guitars compared through the same amplifier with its controls set the same?
  • webrthomsonwebrthomson Frets: 1031
    Another vote for the SD blackouts - I've been using the AHB1 for years having moved from EMG81's.
    The Bill Lawrence L500XL is a pretty trebly pickup compared to the EMG 81 – if you are finding it a bit shrill try flipping it 180 degrees – apparently it’s what Dimebag did with his :)
    Worth looking at the Fishman Fluence modern pickups – they are getting a lot of love from the metal guys at the moment – I’ve got a set but I’ve not dropped them in a guitar yet.
    Yeah exactly. I then tried changing settings and it still wasn't right
  • AlegreeAlegree Frets: 665
    Tonezone gets my vote. Or Airzone if you want to go REALLY fat.
    Have a listen to any of The Offspring for a good demo of what a Tonezone can do.
  • wackojackowackojacko Frets: 59
    Ah that's a blast from the past. Grew up on the early offspring stuff. I read yesterday that Dexter Holland has just completed a PhD in molecular biology.
    Yep it's a sledgehammer of a pickup, without going active and the associated things with that.
    Nothing against it mind, just a bit sterile to me.
    Does either of the guitars have a Floyd Rose type double locking vibrato bridge? If so, from what material is its sustain block made?
    Sterile? I feel the different wire gauges does exactly the opposite.
    Both have Floyd Roses. The Washburn has a big brass block where as the Jackson has the stock steel block. I'm not trying to get them to sound the same, it's just the Jackson sounded way too 'toppy'.
    Changing the sustain block should be cheaper than a pickup.
    I meant the actives.
