Like you said drives are pretty easy to build but delays/modulation can be more difficult as they often need to be biased using an audio probe.
Makes sense that boost/od is easiest. I've made a few, and piece of piss sums it up.
Then again a simple overdrive is the kind of effect you use constantly whether some of the modulation stuff is only on the odd song .. so even expensive overdrives are value for money in terms of cost per usage
With modulation pedals it's what it *does* which sets them apart, and its harder to sell them on the basis of tiny tone differences. Although vibes do seem to be a partial exception to that.
I've made a germanium fuzz, I bought four transistors and all had quite low leakage and three were a good match, it sounds good to me at least. The Phase 45 wasn't too hard either, although I only had to match two transistors for that. I'm looking to build the Harbinger Vibe soon and guess that might be a bit of challenge what with the lightbox etc.
Not something I'd want to try now!
I said maybe.....
No compressor kit on the bitsbox site so I'm wondering if it's because they are a mare?
I said maybe.....
Thank you for the informative post.
