I use a Focusrite Scarlett to record band practise as a cheap way to make band demos.
Keys and bass go into DI with XLR connection to interface and regular connection to amps.
Guitar goes into interface via XLR DI on the amp.
Drums are recorded via one mic above snare.
Vocals (3) go into the PA and a monitor mix is taken into the interface.
I want to be able to record each voice separately straight into interface and put a monitor mix into the PA.
I use Reaper and the interface has 8 XLR/line inputs and 8 outputs using 1/4" jacks.At the last rehearsal I tried an option in Reaper where I was able to select Monitor 1 for lead vocal and Monitor 2 for other vocals. Unfortunately, all instruments that had not been selected also output through Monitor 1 and Monitor 2.
Any advice?
