Tone Magnet
  • OilCityPickupsOilCityPickups Frets: 10346
    edited May 2017 tFB Trader
    If it's strong enough to change the shape of the fields it will eventually f--k up your bridge pickup.  Stuck it to the steel trem block of my Strat too ... same difference ... but along way from the magnetic fields.
  • FunkfingersFunkfingers Frets: 14422
    edited May 2017
    +1
    A Seymour Duncan custom order pickup that I once bought arrived de-Gaussed. Either legendary winder MJ had an off day or the rod magnets suffered in a security scanner.
  • ToneControlToneControl Frets: 11889
    wouldn't the trem block extend the magnetic field out to the front of the guitar?
  • merlinmerlin Frets: 6674
    Thicker strings might do it. No need for magnets....
    ugh
    Dumble HRM clean and a Cali76 ?
  • carloscarlos Frets: 3445
    £75!!! Hahahaha
    Not as much as it does from back the of the bridge ... this all seems a bit like taking a sledgehammer to crack a nut ... that most people preferred nut shaped.
     If the magnet changes the shape of the flux then it will be robbing charge from the weaker magnets and/or re polarising them. When (most) pickup makers charge magnets we are very careful to ensure even field shapes ... I abandoned 'swiping' magnets as that could unevenly charge them ... our big neos are lowered top and bottom till held off contact by a few thousands of an inch ...allowed to charge the alnico to a reference gauss level, then retracted cleanly out so as not to distort the field shape. To my mind messing with big magnets near weaker magnets is a seriously poor idea.
    and they say they worked with the local university to develop this
  • ThorpyFXThorpyFX Frets: 6129
    Gassage said:
    Also,  anyone who wants to dramatically thicken up a Strat tone isn't getting what Strats are about.
    It's rather like saying a Twin Reverb needs a high gain channel.
    it does ;)
    Adrian Thorpe MBE | Owner of ThorpyFx Ltd | Email: thorpy@thorpyfx.com | Twitter: @ThorpyFx | Facebook: ThorpyFx Ltd | Website: www.thorpyfx.com
    Older readers will remember the late Seventies fashion for solid brass hardware. The theory was that increased mass ensured increased mechanical sustain. The one thing that it definitely did increase was the weight of guitars. Tonal improvement is subjective. Many still prefer Leo's original, cheap as chips, bent-over, stamped steel saddle design. This is not because Leo supposedly got it right the first time. It is simply because it contributed to the established Stratocaster sound.
  • SporkySporky Frets: 28125
    I find it a great relief when others post thing like this.
    Which bit? ;)
    I like to draw a comparison between Leo Fender and William Lyons of Jaguar Cars. Both oversaw the creation of some beautiful machines but both could be penny pinching when it came to some of the components.
    The vintage Stratocaster bridge is the most rudimentary POS that would fulfil the required function and be quick and simple for semi-skilled workers to install.
  • thermionicthermionic Frets: 9609
    I noticed the inventor has a PhD. Physics or engineering? No, er, Italian Literature.
    I'd be very interested to see the patent application for this...
    2reaction image LOL 0reaction image Wow! 2reaction image Wisdom
    The inventor says the magnet has the effect, not the weight
    Would the strings not act as pole pieces to the neo magnets?
    I have no idea what would happen then - you'd be putting a field through a vibrating pole (the string) through another field (from the pickup magnet) aligned with the coils
  • richardhomerrichardhomer Frets: 24801
    That's interesting.
    When I asked how it worked - they told me it added more mass to the bridge.
    They probably need to get their story straight....
  • BigMonkaBigMonka Frets: 1770
    Are you hoping it will be written in a beautifully verbose Italian style?
    I don't like the fact it looks like it's got a speaker grill on it. Think it looks a bit stupid.
    Not as bad as this mock up of the T-shirt though
    Medicina di brevetto olio serpente.
  • Lol who would buy this?
    Just turn the amp up a fraction more. Or twiddle the eq a tiny fraction.
    I've clamped things on the headstock before to cure a dead spot on the neck ( fret 11 on the b string - oddly, over time, this seems to have cured itself). But spending that much cash on something that *may* help dead spots and adds a bit of mass to the bridge (= tiny bit of extra sustain, slightly fatter tone) is daft because most amps have an eq.
    Adding just a hair more volume will give a far greater increase in sustain.
