Best Desktop Amp solution
Si_Si_ Frets: 384
HI all.. I've been away from playing guitar for a while but want to get back into it.. All my lovely Valve amps are useless in a small apartment so I want a PC based solution. What's the best one out there a the moment, and what's the best way to hook the guitar up to a PC?
  • BRISTOL86BRISTOL86 Frets: 1920
    I'm using a Scarlett 2i2 with Amplitube 4 on a Mac and I really like it. I need to do some work delving into the tweaking as I find a lot of the tones aren't brilliant straight off the bat, but it's a better solution than a modelling amp IMO.
    To be able to go straight from playing to recording is a big plus. My THR10 could record but the Scarlett is much better as an audio interface.
  • darthed1981darthed1981 Frets: 11743
    I've recorded off the USB on a Blackstar Core 10 - thats kinda fun and dirt cheap
  • fretmeisterfretmeister Frets: 24189
    Helix.
  • Si_Si_ Frets: 384
    Helix.
    I'm on a budget....
  • ModellistaModellista Frets: 2039
    edited May 2017
    The amp sims in the Zoom units are pretty good - G3 or the Multistomps.  You might need an interface or you could just plug into your computer's line in with the appropriate adapter, it might sound fine depending on the quality of the on-board sound card.
  • Shark_EyesShark_Eyes Frets: 377
    The Laney L5 Studio Guitar head has firewire direct out, it's not tiny, but neither is it massive, so depending on your desk size, it could live on your desktop.
    Other plus points are:
    It is an actual tube amp
    Can be used with headphones, and has a good speaker sim
    Can also be hooked up to a proper a speaker cab.
    I use it as my only amp, so could potentially be worth checking out.
    Si_ said:
    Helix.
    I'm on a budget....
    If you give an idea of the budget then our ideas would be more useful.
    Or you could sell a valve amp you aren't using?
    Boss GT-001 sounds good and is pretty cheap, plus the Boss Tone Studio software is very useful for editing patches and you can download patches too.
    The Zoom units do sound good when recording, but they don't have any software to edit on your actual computer, which might put some people off.
  • thermionicthermionic Frets: 9585
    Vox Tonelab, the original desktop model.
    I'd recommend the Zoom G3 or G3x, I have the G5 and it sounds really good through monitors. You can edit patches with the Edit&Share Software and I use Reaper for recording. They can also act as an interface for S Gear, Amplitube and Guitar Rig etc...
  • guitarfishbayguitarfishbay Frets: 7959
    Amplitube 4 is $59.99 until the end of the day
    http://www.ikmultimedia.com/mobile/news/news.php?id=861
  • NelsonPNelsonP Frets: 3389
    Si_ said:
    Helix.
    I'm on a budget....
    I have a POD XT and FBV Express mk2 for sale if you're interested?
  • bloodandtearsbloodandtears Frets: 1655
    Si_ said:
    Helix.
    I'm on a budget....
    HD500X?  Pod v2?
    My trading feedback
  • sweepysweepy Frets: 4180
    Scuffham S Gear followed by BIAS
  • tony99tony99 Frets: 7104
    boss katana, but just make a bit of room for it on the desk
    Bollocks you don't know Bono !!
  • JetfireJetfire Frets: 1696
    Im liking guitar rig but s gear is quality too
  • TimmyOTimmyO Frets: 7392
    If I were setting out to do this now on a budget I'd get a Line 6 Sonicport VX as the 'interface'  and Scuffham S-Gear as the modelling
    Red ones are better.
  • DaveMonDaveMon Frets: 26
    edited May 2017
    If you have or buy a focusrite interface and register it on their website before the end of May you can get BIAS amp for free!
    https://uk.focusrite.com/plugin-collective
  • edbolivaredbolivar Frets: 153
    Apollow twin duo I s great, and not too expensive, but then you open yourself to temptation as lots of amps, effects plug ins, etc are available at extra cost.
    Much better Amp plugins available in comparison to Helix, for 'initially' less money but far less choice unless you spend much more
  • TTBZTTBZ Frets: 2892
    S-Gear 2 has been the best modeller I've tried but I'm actually quite liking the amplitube or120 model at the minute.
