This even on DV247 is worth a punt... only 90 sovs...
http://www.dv247.com/b-stock/jandd-tl-thinline-6-string-electric-guitar-butterscotch-blonde-b-stock--240407
http://www.dv247.com/assets/products/215438_l.jpg
The double locking vibrato system will not be made from premium materials. Hence, on a pre-owned example, the all-important pivot posts and knife edges could be worn to the extent that tuning stability is compromised.
More importantly, perhaps, the budget RG models are supplied with the notorious INF series pickups. You either love 'em or hate 'em. (I, for one, always replace them.)
Over the bank holiday weekend, I have been modifying an RG311M. This model has a fixed bridge. (No vibrato system headaches.) I wanted to use up two EMG humbuckers but the neck/Rhythm position pickup rout was to tight to accommodate one. Duncan Blackouts went in no problem.
Won't help with this question though.
Assuming you want a superstrat type guitar, then have a look at Coda's second hand section, there's a second hand RG1550 for £499. Which is a lot of guitar for the cash.
How much are you looking at spending?
Have you got an amp?
https://www.ebay.co.uk/itm/172700167194
http://www.ebay.co.uk/itm/WASHBURN-NX3-Nexter-Nextar-like-N3-N4-Nuno-Bettencourt-Licensed-Floyd-Rose-SEC-/142393165360?hash=item21274b4630:g:oZkAAOSwWiBY~led
I had one, and it played brilliantly. The pickups were a bit weak, but everything else on it was great; only got rid because I already have an N4 and I got two Jaden Rose guitars, and not much can compete with those three.
https://www.gumtree.com/p/guitar-instrument/ibanez-rg550-made-in-japan-/1242328188
And if not an RG, then something similar - or different!
@Chris777 - drop me a line?
Forum feedback thread. | G&B interview #1 & #2 | https://www.instagram.com/_harry_seven_/
