neck set with a little relief works much better. Loosen that truss rod a smidge
Instagram
Some versions of the Graphtech/TUSQ nut come pre-slotted. This, however, does not mean that the nut is properly finished. Some fettling may still be necessary to the slots.
If a previous owner has fettled but not cleaned up properly where the string leaves the edge of the nut, this can create weird, sitar-like overtones. Another faint possibility is that the nut has a crack in it.
It is worth measuring the spacing between the string slots in the Graphtech nut with respect to the Fender MIM nut width and spacing specifications. If there is a mismatch between, say, Mexican and American specifications, the strings could pass over a taller portion of the frets than the Graphtech designers envisaged.
Finally, did you use a radius gauge to set the heights of the individual bridge saddles?
@funkfingers:
yes neck under string tension
yes I used a radius guage
I will compare the nut string spacing with fender specs when I get some time during the week
thanks
update: I added some relief via the truss rod. I got a clearance of .009-.010 at the 7th and 8th fret. that did calm slightly the buzzing on the A string, but it still buzzes slightly as the string decays.
I checked the nut clearance at the 1st fret (not fretted) although I can't seem to find typical measurement. I watched a youtube video where the luthier suggested .018" or .457mm. my nut clearance measures .009". fretted at the 3rd fret, it measures .003" or 0.23mm
action at 17th fret is at the 2.0mm height
any thoughts?
