That's around 140W ( handbook says 40W ! )
Nearly 72 V pk/pk flat out using EL34/Clean/16 Ohm into a 11.7 Ohm load. Red is 1Khz input. Blue is output.
This is the second one I now know of which is definitely the other way round though - my Ampeg Micro VR, claimed output 200W, claimed input 150W, actually puts out 200W and draws 288W.
So if they're all claiming far less power draw than is actually the case, what happens when you've got a load of these things all running off one lightweight extension cable and the knowledgable user adds up the claimed power draws to work out if it's OK, and thinks it is...
Actually forget that, just looked it up - it samples at 44.1 k although 192Khz sampling is used in audio industry so may be it's an artifact from the chipset used. Don't think you'd want that present in the output stage though.
I doubt a guitar speaker could actually produce it and even if it could it's massively higher than even what a dog can hear.
With a speaker, the physical inertia of the cone is going to mean that a high enough frequency isn't going to be able to get it moving, I suppose if it's strong enough it is however going to be generating heat in the coil and increase the chance of it melting...
Bandcamp
Spotify, Apple et al
