I've got a Honda Precision. MIJ, I believe.
Eqd Speaker Cranker clone
" @ecc83 may know the exact spec but I would guess the two 5" speakers in the ID Core are no more than about 90dB sensitivity, which is around 10dB lower than a typical efficient 12" guitar speaker such as a Celestion V30. 10dB is equivalent to ten times the power - so you would get the same volume from only a *4W* amp through the V30 as from the Blackstar."
I don't know the exact spec of the ID-40's speaker IC (never did and they have probably changed now!) but they are essentially 'quite good' single cone speakers that you would find in a decent, big ghetto blaster! It is the software that makes them sound 'guitary'. And yes, IC, probably no better than 90dB/W/mtr sensitivity sine the amp was never designed as a 'gigger'.
On the valve front the HT-5 would certainly beat the ***t out of the ID! Quite a few people gig with a Five and a 4x12 (yeah! daft I know but if you've got it?...) The HT-5 can in fact put out about 10W of 'pleasant' distortion.
The HT-20 has been mentioned and would probably cope but would be MUCH improved (and a bit louder) if the Rocket 50 was replaced.
Dave.
Hated my HRDx, might just be the fender tone I don't like though. It was just so boring and plain sounding. The only time I managed to get a half decent tone was boosting the gain channel with a tubescreamer to tighten it up.
To be honest I don't think any Blackstar is going to give that early Clapton/Cream sound though. Personal opinion obviously, and I don't doubt someone could prove me wrong - but they just don't sound at all similar to me.
WELL! If we are going to go there! Blackstar ID 100 or 150. Not seen much independent opinion but since they are the same 'engine' as the TVPs but with more sensitive guitar speakers, should be well loud enough.
Easy on the old back to boot.
Dave.
I think someone also said Bluesbreakers era Clapton was not just a Les Paul and amp but there was a treble booster in there also. So, a slightly cleaner sounding amp than you might think plus something giving it a bit of a whack. Rory Gallagher also mostly used a treble booster ( and latterly a Tube Screamer )into small valve amps, Peter Green used one on some stuff, Stevie Ray Vaughan used Tube Screamers as did, IIRC, Santana so a small box on the floor is very much part of the blues rock sound. In more recent years Clapton has used an active mid boost in his guitar doing a similar job.
The odd MJW pops up in the classifieds here and if its the right model for you, you can't do any better.
Likewise if you find the Hotrod Deluxe is too much amp, the Blues Junior is an inferior amp in every way rather than a smaller version of the same thing.
Apparently Wikipedia mentions that Clapton ‘may’ have used a Dallas Rangemaster Treble Booster.
I have just missed a Blackstar HT40 that went quite cheap on eBay for £185.00, so there are still bargains (hopefully) out there. Anyway I still have strong leaning towards a Marshall DSL 40c but maybe I should put the Peavey Classic 50 combo on the list.
I have emailed Coda about their Roiand Blues Cube
It's one of those 'should I ask' but ennspek mentioned that 'The odd MJW pops up' what is a MJW?
Again regards to all,
Colin (or ivor-honda)
LOL. Post that on TGP and watch them kill each other.
