Valve rattle damper rings - anywhere in UK that sells them?
PhiltrePhiltre Frets: 4171
I've got a rattly EL34. Ideally I'd like the damper that Eurotubes sell - http://www.eurotubes.com/store/pc/viewPrd.asp?idproduct=147&idcategory=8 - but they want $15 for postage. Anyone know if this kind of thing is sold in the UK? I Googled it but could only find a dodgy Chinese outfit selling what looked like rolled up condoms.
  • PhiltrePhiltre Frets: 4171
    Ah, thanks!
    "various sizes available to fit most valves" - Do they do EL34 size in that?
    "Not recommended for valves which get hotter than 250c." - is this OK for a EL34?
  • jpfampsjpfamps Frets: 2734
    Or you could buy them from here at about 20% the price:
    https://www.polymax.co.uk/o-rings/rubber-silicone-o-rings/
    Thanks, I'll check that out. =)
  • andy1839andy1839 Frets: 2197
    Philtre said:
    Ah, thanks!
    I've got them in my hifi stuff and guitar amps. Haven't had any issues yet.
    If you mention in the notes what valve it's for they'll send the right sizes.
    Or give the bloke a call and tell him what you're after.
    Ive got two rings on most valves in the combos.
  • ricorico Frets: 1220
    This would solve my rattly valves  - cheers!
  • equalsqlequalsql Frets: 6098
    I just don't get this at all. You can't compress the glass of a valve, so why would a thick elasticated band make any difference?
  • sweepysweepy Frets: 4180
    I used to use an old thick rubber band
    Presumably it dampens the filimant hitting the glass
    Like putting a cloth on a glass would stop it resonating if you hit it with a fork
    I'm a bit skeptical myself but I guess thats the theory.
    edited June 2017
    In my case, holding the rattling valve gently with a cloth stops the rattle. So I think a thick rubber doodad might work. At least I'm going to try it.
    I don't get this either.   If a valve is rattling wouldn’t that mean it's loose in the socket, or that the socket is loose in its mounting?  Or am I totally missing the point here?
    It's filament rattle. And, yes, a silcone damper works.
  • MistyMisty Frets: 135
    If it's filament rattle dampers definitely work, but as has already been said, get ones that will definitely take the high temperatures involved. I bought some off eBay once for my EL84s, and I could tell very quickly from the smell that they were overheating. I then got some from the US which are perfect.
  • ToneControlToneControl Frets: 11884
    viton is better than silicone, it takes a higher temp
    I've used them for years
    I use to get valves in an amp headsin the room vibrating and rattling when a different amp was being played
    I assume it's the resonant frequency of the glass tube or the filament structure - adding dampers around where the metal structure is, and sometimes also a quarter of the way in from the top and bottom does work
    That's exactly the case for my rattly valve. Playing C# (fairly loudly) creates the resonance
    Where did you obtain the Viton ones?
    They arrived. I put them on the rattly valve and it no longer rattles. They're silicone and can take the heat.
    Result.
    Thanks.
    I got them from http://www.polymax.co.uk,
    viton takes a bit more heat
    some output valves run a bit hotter in some amps
    fatter rings (more cross sectional area) do a bit more, but are tighter and cost more
    Result.
    Thanks.
    Great, I'm pleased it's sorted for you mate.
    Andy
