i re-wired epiphone last year and it was short shaft.
so the correct answer is whichever size are in there now.
Instagram
Some of the older ones were short shaft, but with metric holes. So you'd need to ream them out for CTS.
Some of the new ones come with CTS pots, so the holes wouldn't need enlarging. Some will be long shaft...
They have started to do metric sized CTS pots though.
https://www.axesrus.co.uk/1-x-CTS-Pot-Split-Shaft-Metric-Size-p/cts59met.htm
They seem to be 'medium' shaft, so might be just the ticket. Won't know until you have it in your hands.
I got a long shaft les paul wiring kit in the end and reamed the holes out to 10mm diameter for the CTS pots.
thanks for the heads up though!
