This - https://www.technologysupplies.co.uk/antex-soldering-iron-tcs-50w-230v-silicone-cable.html
I prefer to a solder station as it's easier to put away in a drawer - it's temperature controlled, it's Antex so tips are readily available and with the right tip you can easily solder on the back of pots - without them even feeling warm afterwards - makes soldering a doddle - I have a 6mm tip that will solder anything!
That looks pretty good - a degree of temperature control for the price of a bog-standard Antex.
Maybe get a bigger bit for soldering the back of pots (bigger bit retains/transfers heat better) and keep the original bit for more intricate work.
My first foray into soldering a couple years back was with a very cheap iron and all it managed to heat was my fingertip.
Thanks to everyone who popped in to help!
PS - get a 6mm and a 1mm and with the tip that comes with it you'll be covered for just about anything guitar related.
https://static.rapidonline.com/catalogueimages/Product/S86-0350P01WL.jpg
https://www.rapidonline.com/anvil-light-duty-wire-stripper-30555
I've got various wire strippers, each for different jobs, but for the teeny little wires in pickups I like these best.
