at the top end strymon sunset or kingsley jester.
cheaper good options I've had are trex gristle king or the trex moller, HBE power screamer is an excellent pedal as well.
amp 11
box of rock
carpe diem
full drive 2
theres probably a whole load more to be found once you get stuck into some solid googling
It's got a subtle yet clear voice, goes from clean boost to higher gain grit and a variety of tones on tap via the filters. Stacks really well with overdrive and fuzz.
Not for everyone, but if you are trying out pedals I'd recommend a test.
Bogner La Grange has independent post-dirt boost.
Weehbos like JCM & JVM have boost but think only work when dirt is on (iirc), if that matters.
You can have two drives either the same sound or two different voices, two boosts, one with more gain than the other or a drive and a boost depending on which pedal you choose
