Hi all, would appreciate help on a troublesome amp hum that has recently occurred in my Two Rock Exo 15. Amp was retubed about 9 months ago and has been sounding great and super quiet up to now.
Switching the amp on from standby there is a hum, sounds like a ground hum, pretty low pitched and does not vary within change in amp controls.
Hum is present with gain and master on zero.
Hum is there with and without guitar plugged in.
Amp is still sounding great when being played, just the hum is annoying..
Hum is there when I try the amp in another room.
The amp has 5 tube, v1 is preamp, v2 is PI, v3 is rectifier, v4 and v5 are power tubes.
Removing v1 makes no difference to the hum.
Removing v2 results in the hum disappearing meaning issue is upstream. Have tried various 12ax7s in v1 and v2 with no change.
Any thoughts???
Do they perhaps elevate the heater line a few 10s of volts to give the PI h/k an easier time and the +ve DC has gorn?
Could be a failed HT filter cap but modern electro's are very reliable.
Dave.
It was caused by a power valve with a cathode to filament leak putting hum into the filament loom.
If the amp is fixed-bias (I think it is), trying pulling each power valve in turn and see if it stops.
@ICBM - I'll try that later. Thanks!
Next step will be to rebias.
Time for an amp tech? Can't think of anything else I can try, could try a 12at7 instead of a 12ax7 as the PI or swap out the rectifier tube, but can't see those making a difference.
Anybody know of a good amp tech in N. Ireland?
