Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
Rift Amplification
www.riftamps.co.uk
With a 10W amp and a 25W speaker you're below the point at which that's an issue though, so in general there will be very little difference between that and a 75W speaker, other than that different speakers sound different and have different sensitivities (efficiency) - which are not related to the power rating. Contrary to popular myth there is no reason you need to 'drive a speaker fully', so the 75W one will work just as well. There are a few speakers which can sound a bit stiff and harsh at *very* low power inputs, but 10W should be enough for any of them.
The last time I blew a speaker testing something was when I connected an amp with an intermittent DC output fault directly to a V30 cabinet… a few seconds of normal sound followed by a loud pop and smoke, which was annoying! I usually try to be more careful than that with solid-state amps - I'm not even sure most 150W speakers would withstand it.
In terms of what you hear, the sensitivity of the driver can make the amp appear much louder or quieter. Again the human ear can play tricks because certain frequencies might be more or less sensative in a given brand/type and the ear picks up on the whole speaker being louder because these frequencies cut through.
If you like the sound of a driver in the given box and it matches the amps specs, you're good to go. If you don't like the sound, change it.
