How should I take off white spray paint from body?
lukedlblukedlb Frets: 488
edited June 2017 in Making & Modding
In my younger days I foolishly spray painted my vantage guitar with white spray paint (yes, just regular white spray paint). a bit of body heat and the paint still gets sticky from over 25 years ago. I sprayed it directly on top of the varnished wood.
I'd like to restore it to its original state in the easiest way possible. Would thinner do it?
  • WezVWezV Frets: 16645
    Test some things in the cavities. Thinners may work, even paint stripper.
    If you are lucky the chemicals will work on the top layer but not touch the original finish.
  • CorvusCorvus Frets: 2925
    Exactly as above, if the original lacquer is the usual two-pack, it's not much bothered by cellulose thinners. But that will dissolve the 1k spray paint on top of it. Do test though.
    Seed trays or the like are handy, you can soak a paper kitchen towel in thinners and lay it on. After a few secs start to wipe off with it. It works but is quite messy and fumey, gloves, mask & outdoors etc. Once the worst is off go over with damper towels and wipe off the leftovers.
  • lukedlblukedlb Frets: 488
    thank you @WezV ; and @Corvus. I'll give it a try this week.
  • JalapenoJalapeno Frets: 6385
    Get a mask .... ;)
    Feedback
  • SargeSarge Frets: 2376
    My default for spray paint removal is acetone, but standard thinners will do the job too.
  • impmannimpmann Frets: 12663
    Acetone - otherwise known as nail varnish remover...
    Standard nail varnish remover isn't suitable as It contains oils and perfumes unsuitable should they get into bare wood.
  • trolleytrolley Frets: 88
    I have a Mystic Dream |JP-6 that some dickhead oversprayed white!
    The next owner (before me) stripped all of the white off using wire wool. It took months, but now I own a 'relic'ed' JP-6 Mystic Dream. And apart from a couple of dinks & a few scratches it's fine.
    He sent me a Word doc with pictures showing the whole process - it's very impressive. I wouldn't have had the patience - but that's the key. Little by little
    edited June 2017
    This. But you can still pick up pure acetone from Boots etc if you can't be bothered ordering it online, just have a root around the aisle - in a manly kind of way.
    Apart from needing a good amout of solvent to do a whole guitar, acetone can attack the 2 pack clear underneath so i wouldn't use it in this sort of job.
  • thermionicthermionic Frets: 9583
    Ah, Vantage, not Vintage!
    If it's that era there's a chance it could be polyurethane, which is attacked by cellulose thinners though less so than 1k rattle can paint, so go easy. Start with 'less' and go wetter as needed when laying on sheets wetted in thinner. After just a few secs the topcoat will soften & wipe off.
    Equal or better chance the clearcoat's two-pack/urethane which will be OK with celly thinners.
    Sorry , corrected.
    I de-pollocked an aria cardinal bass that had been sprayed badly  with white paint first
    Started like this and you can see someone had already  had a go at cleaning it up
    thinners got right through the white pain, but didn't touch the splats
    A cheap paint stripper did the rest, and didn't touch the original finish... but it was quite worn underneath
    Just try any of the stuff recommended above and see what happens, worse case is you remove the original  finish... but if that happens a clean up and oil would make it look pretty nice
    Nice save Wez, "de-pollocked" LOL. Enamel toughens with age, for a (usually) cheap paint it can be a bastard to get rid of.
    edited June 2017
    Ah Vantage Matsumoku era (lovely guitar btw)
    That'll be catalysed polyester (aka Imron) NOTHING will get through that but a pneumatic hammer
    I've done quite a few of this era Mats poly clean ups (inc a vs600 bass) and acetone was my method, soaked a small pub towel and rubbed it off no bother.
    @Sarge makes it sound so easy. 3 hours in and less than a third done. Perhaps the pub towel's abrasiveness helps. I can't see any damage to the original imron. Photos coming.
