I have a question regarding 2-channel amps:
When you switch to the gain channel there's more gain on tap, is it 'cause an additional gain stage gets engaged or are there other electronic bits like FETs and diodes that change the sound?
What if there is just one preamp valve like my old HT5? I assume each channel shares half of the valve so what happens when you change to the OD channel and you get "more" ? Higher signal? different pots, caps and resistors?? (I understand pots are basically attenuators so different values will let more-less pass through)
What about Mesa amps where you flick a switch and you get, say, "Burn" or "Red" or whatever..
Whereas with a single channel amp it's simpler, you crank the volume and you get OD.
Is it really more valve-tone or other bits as well (like pedal circuitry)?
Sorry if this is a silly question but I've been interested in Mesa amps since I got my LSS and all these switches make me think that after a point I am just engaging pedals built in the circuit. The tone is lovely and "amp-like" obviously but is it as pure valve saturation as most people think?
I'd appreciate any info pls.
the dam analogy is really good. are >1 gain stages a feature of dedicated dirty channel amps or they work in single channel amps too? clarifying that would help my understanding of it I think. I'll do some digging.
