I dare say that there is a way to do this but I am unwilling to risk damaging the machinehead just to find out how.
If you have a broken one, this would be the ideal opportunity to force it open and find out how it's done, for future reference - although it's almost certain that re-assembling one would need whatever tool they use at the factory anyway, so I'm not sure how useful it would be.
@Funkfingers I got as far as you and then stopped for the same reason. Perhaps I'll try YouTube again, and try some other forums before sacrificing it, but I haven't been able to find anything yet - perhaps the reason is simply that there isn't a practical way to do it.
@ICBM, as I said above, I'm not quite ready to sacrifice it yet but if that happens I'll certainly share for the benefit of others. Do you think it might be worth trying to flush the shaft out in case there is a bit of something stuck in there. Or will it just wash out the lubricant from the main tuner mechanism? Also, are the Schaller version constructed differently? If so, I might keep an eye out for those if I ever need another set!
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
