I keep breaking strings and it's doing my head in!
It's happening on both my Tele and Les Paul.
I use D'Addarios 11-48 tuned to Eb.
I've checked the pack is legit using their online checker/qr code thingy.
I use the Dunlop Black Jazz Xl Tortex picks usually.
If.... Rather when u change strings, I usually get a couple hours straight practice out of them then the next time I play I dually break one. Practice, as in band practice, not just widdling at home.
I'm guessing I'm just a heavy player and need to not smash the granny out of everything (pick a bit lighter).
Any other thoughts?
If so, where?
What restringing method do you use?
heck out any break at contact point first
That sounds like corrosion spots forming - usually at the contact points, particularly the bridge saddles - so the next time you play the string is weakened there and snaps.
I've taken some very fine sand paper to each of the saddles to ensure there are no sharp edges that may have been missed.
At a bit of a loss really!
I have lighter plectrums I will try, both jazz xl and standard sized
In my entire playing career, I've hardly ever broken a string - so I reckon it has a lot to do with technique.
A heavy right hand may well be your issue....
contactemea@fender.com
Only ones I've not broken are low and high e!
Obviously an airy-fairy limp wristed string-tickler
You've probably broken more strings in a week/month than I have in 10 years
maybe stupid question but are the saddles worn - saddles on a 'cheaper' guitar, often with money metal can be bad, but unsure what guitar you have and even if saddles are worn by the contact area - again is the break angle to steep on either guitars
My Richie Kotzen tele is about a month old, I'm on my 3rd set of strings with that
