I use Boss FV-500 pedals with the Axe-FX
they're great..
There are two basic types - variable resistance, and potential divider. A variable resistance type will use a mono (TS) jack or captive cable/plug, and needs to be the right resistance to work with the unit or the control range will be wrong.
A potential divider type will use a stereo (TRS) jack or cable/plug and doesn't need to be a specific resistance, but some are also connected differently - some have the tip and ring connections reversed, and if you use the wrong one it will behave oddly.
In order to use it as a switch, the unit it's controlling will need to be programmed so that a particular range of control values can be used to toggle the effect on and off. I can't answer that for the Headrush unfortunately.
I don't think the Headrush has the option to auto-engage the wah but I'll check...
https://www.amazon.co.uk/gp/product/B0786XL4PD/ref=ppx_yo_dt_b_asin_title_o00_s00
