For some time I've been thinking about putting a Bigsby B5 style tremolo on my Epiphone SG. Not a real Bigsby but one of those £25 made in China jobs from Ebay that Jooky has used. I was poised over the buy it now button when I realised that I would have to remove the stop tail post mounting thingies. I Googled that and it looks fairly straightforward but then I read that the electrics are grounded to the cup that holds the bottom post. Presumably if I remove it then I would have to ground it somewhere else. I want to put the Bigsby over the holes and I wondered if I could just extend the ground/earth wire up the hole so it contacts the back of the tremolo. Can anyone advise if this would work or if there is a better method?
You may also find this useful - how to make sure the Bigsby is in the right place to drill the screw holes. You can move it around a bit and check the alignment and measurements to the bridge before you mark the positions...
http://2.bp.blogspot.com/-m6QRu1m4vDw/U8bHLzVLjFI/AAAAAAAAENM/mQgHpqEI-c8/s1600/Rickenbacker+capri+John+Lennon+5.jpg
http://www.zeblog.com/blog/uploads/i/ik/pouet.jpg
https://a2-images.myspacecdn.com/images03/13/f5efc879bddf4c76bdbbe041e79cd875/full.jpg
