Sanding
Any advice on sanding bodies? When I did the first wudtone coats, I found that I had little scratches in the wood and the belly cut wasnt clear of the previous wudtone. Is it just a case of going through the paper gradings to make sure it they are sanded out. Any handy tips for the belly cut and horns?
  • CorvusCorvus Frets: 2925
    In general, go through grades till scratches are gone, a wipe with a solvent can help show them up on bare wood. Don't jump grades too much esp with the starting coarser grades.
    Use sanding blocks - buy or make. I use a set of hard foam ones, various shapes, but have made them from wood, rubber/copper/steel tube, wood sticks etc etc. Fingers/hands just ride over ripples and blocks are way faster anyway.
    For a gentle curve like a belly cut a small foam block and 1" - 2" dia cylinder block works. Scrapers can be great too, and fast. Both curves and inital hogging off old finish on the flats but I finish off with sandpaper because you feel low/high spots better.
    The right paper helps. I like 3M Fre-Cut for most things but it's not cheap, it's a dry sanding paper. De-clog with your missus' toothbrush (other stiff brushes are available) makes it last longer and keep cutting.
  • JetfireJetfire Frets: 1696
    Actually, the curved sanding block is a genius idea for the belly cut!
