Just wondering about this - I've been looking especially at the Boss GT 100 and also Line 6 Pod HD500X on Youtube but hard to come to any kind of conclusion, and I guess there are plusses and minuses for both. Or, since I have a couple of drive pedals I like a lot, maybe I could get the new Boss MS-3 to use with those. Whatever, I'll almost certainly go with a simple guitar into effects into clean amp kind of setup - that's what I do now with my pedal board. Whatever setup I have needs to be capable of standing up to gigging use, both in terms of sound and durability. Just any thoughts welcome anyhow, cheers.
The only exception that I make to this sweeping generalisation is the Roland VG-99. Obviously, in that instance, the original pitch controlling signal does not always behave like a normal electric guitar anyway.
In answer to your question, I would go the individual pedals and switcher/controller route.
I've been round and round with pedal boards and really if it sounds good enough it is good enough.
I have a small boss only board. An insane moogerfooger and other expensive stuff controlled by boss es5 board and a helix.
I use the small board and the helix most. Both sound great. Both serve their application well.
If you have dirt you are happy with, go try the ms3. Sounds like it could be a good fit.
Thanks - I think you're probably right, I should look at the MS-3. From what I understand, it's not quite perfect for me - I wish it had at least one stereo send and return loop, that could be positioned at or near the end of the effects chain, the reason being I am addicted to the particle reverb on my Zoom MS70-CDR. But I guess I could put that unit after the MS-3, and then it's only one more footswitch to operate to add that. Another plus point for the MS-3 is that I can use my existing F500H volume, which I like, as a volume/expression pedal, and also my Hardwire HT-6 tuner pedal could surely still be on the board - I suspect that will be better/more visible than any built-in tuner.
So I'm still using my Vox Tonelab SE and Tonelab LE units. They may be 'old technology' but (without going into Helix price territory) these are still the best sounding units I've found that are easy to use on stage.
Cheers - obviously good stuff.
I was thinking that too.
Boss GT-100, GT3, or GT5
TC Electronic Nova System
You could try any of those.
It's a blessing to get rid of patch leads and power supplies.
The size of it is something I like and the screens are really good, removing the need for what's been termed 'Scribble Strips', which I find actually quite hard to focus on.
I can't afford either Helix and I sold the pedals I had for just the right amount to buy this GT100 so it worked out really well for me.
I just don't get the criticism of the drives or the amp modelling, I find them totally amazing and as accurate as I would ever want them to be. There's a load of patches created by various artists you can download from Boss and Josh Munday has made a load of song specific patches which work really well and sound very authentic.
I was happy anyway to clean up what's on the floor in front of me but I've been nothing but impressed with the sounds and the depth of the unit and what it will do. Every time I use it I find something new (It's still only a few weeks old for me) and whilst I admit it's not a Helix, it feels to me like I could use a lot of what this unit offers where I keep thinking a lot of what Helix has to offer would go unused for me. Maybe that's my budget talking and I would find myself using more of a Helix than I think but I don't feel like I've missed out by having the BOSS. I call it a "Low Fat Helix", which to my mind makes some sense and I'm quite happy with not owning the latest thing, which is something I'm used to anyway.
Whatever comparison you make, for £350 you get so much in this that the value for money is off the scale and with 200 user presets to use, proper Bank up/down pedals and a really good onboard tuner, it's everything I need.
I did also buy the BOSS FS-5L to sit alongside it, purely because I have it assigned as an instant Tuner access switch. On the GT100 you need to press Number 1 and 2 pedals together to access the tuner and I watched a demo (Brett Kingman *I think*) where he used a switch to remotely operate this and it makes it a LOT easier. I'm not sure that if I didn't hit both switches together perfectly it might or might not mess up the patch I was on but this way is just really simple and I wasn't using the SUB/EXP control port for anything else anyway.
There are no 'Loops' like there is on Helix, it's just the Send/Return main loop which you'll use if you're in 4cm but if you're not then you can 'Inject' other pedals into the chain and you can move them around and put them wherever you like, just like Helix can but in 4cm you won't have that functionality.
I love what I've got and I'll be using this for a long time to come now.
Hope that helps somehow.
Re amp tones its not so much the modelling but the feel and overall sound. The Boss GT100 on paper has modelling that's more accurate/modern compared to the Tonelab LE/SE. But even so, there's just something about these older Tonelab units (note: the later TonelabEX isn't the same and doesn't have the on-stage live features I need) that feel and sound like you're playing through a real amp - the valve & valvereactor design isn't marketing hype, it really does help with that real amp 'oomph' that I just couldn't get with any other MFX unit - it goes beyond the mere modelling accuracy (which more modern units like the GT100, G5, HD500 etc do far better).
It's very hard to explain unless and until you play them side-by-side (which I did). I REALLY wanted the GT100 to 'fit' what I needed. It's more modern, has dual screens, more modelling, more effects, better connectivity, good switching, right price point etc and I like Boss gear because it's just so well made and designed. But try as I might I just couldn't get that 'something' I get from the Tonelab LE/SE.
Drop me a PM and come round for an hour.
I've got 5 very different guitars here and a Marshall Code 25 amp so there's more than enough variety to see what it will all do, we can hook it up to the laptop and if you can show me how to work a recording program like reaper, you can record it and take it away with you.
Seriously I do very little these days so you're not imposing and if you're thinking of actually buying one, give it a proper go before you do, no problem.
The only drawback is the parking situation. There's only one place to park, it can get very full and it's pay and display. The wardens around here are Nazi's so there's no other option but that aside, you're most welcome.
I certainly prefer it to my Pod HD500 - which I've been wrestling angrily with since I foolishly sold my M13 to buy it at launch.
Actually the new Boss MS 3 probably makes even more sense because of the loops and it's size but no one seems to like the screen and it costs more than the GT100 to give you the same effects.
@Grumpyrocker - my current board actually has a Zoom G3 to handle delays/reverbs/modulations/filter etc. effects (also a Zoom MS70CDR) - and I tend to agree with you about the sound quality of the effects, and the range of them, and also I like that I can have any 6, including several of the same type, in any order. It's great in many ways, but it's become apparent to me that I really need/want better patch switching i.e. the ability to change between completely different patches with one footswitch press. If Zoom made their own version of the Boss MS-3, or perhaps a bit expanded from that, that might be a winner for me.
