Ask yourself what you want out of the Muffroom, and what kind of tone you're aiming for. Alternatively consider what pedal do you want to give the priority to? You might find the position depends on the settings you want to use, and the music you want to play.
Boosting a Muff often sounds good and I also like the sound of other drives following them: so putting it in the middle gives you both options.
Really tightens it up
